expression in mapserver
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed May 2 09:59:45 EDT 2007
Thanks. works for me now.
Steve Lime wrote:
> Found and fixed the problem...
> Steve
>>>> Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> 05/01/07 9:21 AM >>>
> Stephen Woodbridge wrote:
>> Yewondwossen Assefa wrote:
>>> Hi There,
>>> Using mapserver for svn, I am running into a problem where class
>>> expressions seems to not validate : I have an expression which looks
>>> like this :
>>> Layer
>>> Class
>>> EXPRESSION ("[Capital]" = "1")
>>> The evaluation of the expression in msEvalExpression return always
>>> false.
>>> This expression is valid with a build of Mapserver done early last week.
>>> Did some one have a similar issue ?
>>> Thanks
>>> PS : I am running on windows
>> Assefa,
>> This is probably not you problem, but when I look at the expression
>> above the following alarms sound for me:
>> 1) Capital vs CAPITAL
>> 2) = vs ==
>> 3) Do you need the quotes about "[Capital]"? I thought not.
>> -Steve W
> Steve,
> I tried it with different combination (Capital vs CAPITAL, = vs eq,
> quotes and no quotes). The thing is that this same map file with the
> expression works with a MapServer build from last week but not that one
> I grabbed from svn yesterday. It might just be my build which is not
> correct but wanted to know if others have the same issues (at least on
> Windows).
> Thanks.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
