linking Trac and subversion
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Wed May 2 11:48:59 EDT 2007
Hi list,
why are the developers not using links between Trac and svn?
In the Trac ticket you can do something like:
Fixed in changeset:6072, which will create a link to the changeset in which
the ticket was fixed.
Also, when doing an svn commit one should use the ticket: syntax in the
message, for instance:
svn commit -m "ticket:2079 WMS request with a BBOX and and SLD containing
Filter encoding gives inconsistent result"
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
