linking Trac and subversion
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Wed May 2 11:53:19 EDT 2007
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Bart van
> den Eijnden (OSGIS)
> Sent: 02 May, 2007 11:49 AM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-DEV] linking Trac and subversion
> Hi list,
> why are the developers not using links between Trac and svn?
> In the Trac ticket you can do something like:
> Fixed in changeset:6072, which will create a link to the
> changeset in which the ticket was fixed.
> Also, when doing an svn commit one should use the ticket:
> syntax in the message, for instance:
> svn commit -m "ticket:2079 WMS request with a BBOX and and
> SLD containing Filter encoding gives inconsistent result"
Good to know!!  If this is the agreed-upon approach, this would be
useful.
..Tom
