RFC 26 - MapServer Terminology Cleanup
    Steve Lime
    Steve.Lime at DNR.STATE.MN.US
    Mon May  7 16:20:16 EDT 2007
That's a pretty big change for folks to have to go through every layer and set "QUERYABLE TRUE".
Default should probably be conservatively set to FALSE.
Steve
>>> On 5/7/2007 at 10:06 AM, in message <463F4093.2080206 at mapgears.com>, Daniel
Morissette <dmorissette at MAPGEARS.COM> wrote:
> Steve Lime wrote:
>> Is there a way we could do this in the code without adding a new parameter?
> I'm
>> thinking probably not since you can use layers with WxS service parameters
> defined
>> with the CGI or MapScript... So, I would propose recognizing the template or
> a queryable
>> parameter.
> What if someone sets TEMPLATE "something.html" and also sets QUERYABLE
> FALSE. With what you propose the QUERYABLE setting would be ignored and
> the layer would still be queryable, right? That would be creating
> another source of confusion. I think if we add a QUERYABLE TRUE/FALSE
> setting then TEMPLATE should be treated as a simple parameter and
> queryability should be determined only by the QUERYABLE setting.
> That's just my opinion, let's see what others think.
>> Since we have a function like msIsLayerQueryable that should be easy
>> enough.
> I think there's more to do than just updating msIsLayerQueryable().
> First there is the class by class queryability that is not handled by
> msIsLayerQueryable(). I also did a quick check and there is lots of code
> that checks the layer and class template values directly and would need
> to be updated. There's also some code (mapwfs.c) that sets dummy
> template values that we could finally get rid of. I could take care of
> the implementation if you want.
> Daniel
