Subversion cleanup
Jani Averbach
jaa at JAA.IKI.FI
Fri May 18 10:52:43 EDT 2007
Hello Daniel,
Daniel Morissette wrote:
> However, before we move stuff around too much, you should all be aware
> that even though SVN allows you to move files/dirs around apparently
> seamlessly, once a file has been moved to a new location you cannot
> checkout a revision from before the move with a simple "svn update -r
> <revno>". You have to use the explicit path to where the file used to
> reside at the time of that revision to get the file... which implies
> that you need to track down the file, or checkout a copy of the whole
> repository if you don't know where it used to be.
SVN's peg-revision does this for you, please see following
SVN Book link, there is a good explanation how this works:
http://svnbook.red-bean.com/nightly/en/svn.advanced.pegrevs.html
Best Regards,
Jani
Jani Averbach
