MapServer OSGeo buildbot configuration
Steve Lime Steve.Lime at DNR.STATE.MN.US
Tue May 22 01:01:04 EDT 2007
Whoops, missed your reply.
  - The output for the 3 perl steps looks fine.
  - the make install step does modify the system installation. You could install perl in the local MapServer buildbot area and use that instead.
  - there is no make test, maybe we can coax Tom K. into working on one? Wouldn't be as comprehensive as the Python suite but it wouldn't be hard to verify it installed ok using the test data in the distribution.
Steve
>>> "Tamas Szekeres" <szekerest at gmail.com> 05/14/07 5:45 PM >>>
Steve,
I've added some steps to the telascience slave. Would you confirrm
that the stdio of those steps show the expected results?
I'm a bit uncertain about the make install step. Does it make some
system wide actions or it can be restricted to a particular folder to
be affected?
Do we have a make test target and how can I make it work?
Best regards,
Tamas
2007/5/14, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> Thanks for the hard work on this. For perl on Linux the build is very straight forward:
> Perl Makefile.PL
> make
> make install
> It expects the mapscriptvars file to exist. I've only tested personally with Perl 5.8 and
> higher.
> Steve
> >>> On 5/13/2007 at 5:08 PM, in message
> <f3b73b7d0705131508o26aad0f6h305cc4702940f9f0 at mail.gmail.com>, Tamas Szekeres
> <szekerest at GMAIL.COM> wrote:
> > Folks,
> > The OSGeo buildbot for MapServer have now been set up with 1 Linux and
> > 2 Windows buildslaves (VS2003 and VS2005 builders).
> > I would encourage everyone who make a substantial change in the
> > svn-trunk to trigger a build on each platform and make sure the change
> > does not affect any of the builders.
> > The full builds are triggered automatically in every 12 hours.
> > In the future I'm planning to add the python tests to the builders and
> > I would also like to see to buildsteps for each SWIG bindings.
> > In this regard any short description about the build process including
> > the expected environment settings and software versions for the
> > various languages are highly welcomed.
> > Best regards,
> > Tamas Szekeres
