MS-RFC-27: Label Priority
Daniel Morissette dmorissette at MAPGEARS.COM
Thu May 24 16:14:01 EDT 2007
Steve Lime wrote:
> Regarding priority binding. You wouldn't add a new keyword, rather you'd support
> both inline setting of priority (e.g. PRIORITY 5) and via binding (e.g. PRIORITY [prioritycol]).
> I didn't read the RFC to see PRIORITY is a label or class parameter. Right now labels
> and styles support bindings but classes could too if necessary.
PRIORITY is a LABEL parameter. I had not looked at the way RFC-19 was
implemented yet, I just had a quick look and it seems that PRIORITY
binding will fit very well in the current system.
I'll add info about that to RFC-27.
> Would suggest a quick macro for any priority bounds testing so it could be used during
> a mapfile parse as well (MS_IS_VALID_LABEL_PRIORITY).
Good idea. I'll add that too.
Daniel
Daniel Morissette
http://www.mapgears.com/
