mapserver svn issues
Matthias Pohl m.pohl at M-CLICK.DE
Thu May 31 03:41:02 EDT 2007
Hello list,
1.) when compiling mapserver on a 64bit AMD processor (Debian Linux), we
found a typo in mapserver-4.99/map.h
Index: mapserver-4.99/map.h
--- mapserver-4.99/map.h	(revision 6159)
+++ mapserver-4.99/map.h	(working copy)
@@ -67,7 +67,7 @@
  typedef long            ms_int32;
  typedef unsigned long   ms_uint32;
  #elif UINT_MAX == 0xffffffff
-typedef int             ms_uint32;
+typedef int             ms_int32;
  typedef unsigned int    ms_uint32;
  #else
  #include <stdint.h>
2.) The php mapscript ms_newLayerObj() function shows an error "Fatal
error: [MapServer Error]: initLayer(): Layer is null in /script.php"
The patch will fix the problem.
Index: mapserver-4.99/mapscript/php3/mapscript_i.c
--- mapserver-4.99/mapscript/php3/mapscript_i.c	(revision 6159)
+++ mapserver-4.99/mapscript/php3/mapscript_i.c	(working copy)
@@ -462,6 +462,10 @@
      if(map->numlayers == MS_MAXLAYERS) // no room
        return(NULL);
+    map->layers[map->numlayers] = (layerObj*)malloc(sizeof(layerObj));
+    if(map->layers[map->numlayers] == NULL)
+      return(NULL);
      if(initLayer((map->layers[map->numlayers]), map) == -1)
        return(NULL);
regards, Matt
