mapserver svn issues
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu May 31 10:32:20 EDT 2007
Thanks. I have commited the fix. Same type of errors were also corrected
when creating new class and styles
Later,
> 2.) The php mapscript ms_newLayerObj() function shows an error "Fatal
> error: [MapServer Error]: initLayer(): Layer is null in /script.php"
> The patch will fix the problem.
> Index: mapserver-4.99/mapscript/php3/mapscript_i.c
> --- mapserver-4.99/mapscript/php3/mapscript_i.c (revision 6159)
> +++ mapserver-4.99/mapscript/php3/mapscript_i.c (working copy)
> @@ -462,6 +462,10 @@
> if(map->numlayers == MS_MAXLAYERS) // no room
> return(NULL);
> + map->layers[map->numlayers] = (layerObj*)malloc(sizeof(layerObj));
> + if(map->layers[map->numlayers] == NULL)
> + return(NULL);
> if(initLayer((map->layers[map->numlayers]), map) == -1)
> return(NULL);
> regards, Matt
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
