Call for comments - RFC 36
Steve Lime Steve.Lime at DNR.STATE.MN.US
Mon Nov 5 14:18:56 EST 2007
Comments inline... Steve
>>> On 11/2/2007 at 1:45 PM, in message <472B7042.5010904 at mapgears.com>, Daniel
Morissette <dmorissette at MAPGEARS.COM> wrote:
> Steve Lime wrote:
>> Hi all: I (with the help of Tom K.) put together an RFC outlining better
> template support
>> for queries via the CGI interface.  Please take a look at:
>>   http://mapserver.gis.umn.edu/development/rfc/ms-rfc-36/
> Steve, Tom,
> I like it. I have a little fear at the back of my mind that there might
> be some aspects/issues that we didn't think of and are not covered, but
> overall that sounds great.
One area would be in mixing feature drawing and query result presentation. I don't *think*
that is an issue since we explicitly decide which drivers to use in each situation. One area
that might been an issue is automatic format enumeration for OWS services.
> Here are a few comments and answers to some questions that you raised in
> the document:
> 1- Do we need to require that start/end tags be on their own line?
> This is handled by getInlineTag(). I didn't test, but from a quick
> browse of the code I think they can be anywhere on a line. That would
> remain to be verified of course. Some of the template parsing functions
> added for the HTML template stuff may not be optimal and could possibly
> use some optimization work.
I don't know without working on the implementation. Ideally no, but I figured I'd start
conservative and drop that requirement if the code used for HTML legends was sufficient.
> 2- Dig Dan's proposal for a queryable flag out of the -dev archives.
> Here is what I had written when we discussed the terminology cleanup RFC:
>> An option might be to add a QUERYABLE TRUE/FALSE keyword to the layer and
> class objects, that would determine whether a layer/class is queryable or
> not. Then to query through the CGI you'd also need to provide a template (or
> otherwise mapserv would issue an error saying that TEMPLATE was not
> provided). The big benefit is that MapScript apps (and WMS services) would no
> longer need to provide dummy templates.
Personally I think this is a good idea for 5.2 independent of this RFC. Question is
do others, and who would do this.
> 3- Backwards incompatibilities:
> You wrote "No other compatibility issues are anticipated." which implies
> that the reader needs to dig through the text of hte RFC to find out hte
> list of incompatibilities. I think they should be explicitly listed in
> that section again. Off the top of my head they would be:
> - TEMPLATE keyword removed from LAYER/CLASS and moved to OUTPUTFORMAT
> - QUERYABLE parameter must be used to mark layers as queryable
> - Template format has changed. Now [resultset] and [feature] blocks in
> the main template replace former header/footer templates
> - ... Did I miss any?
The reason I wrote none were anticipated is because we'd still support the current
system.
> 4- With this new system do we lose the benefit of being able to reuse
> templates, headers and footers between layers? Now we'd need to
> duplicate them for each layer inside the [resultset] blocks, could that
> become an issue for very large mapfiles?
I'd propose adding an [include src="..."] tag as part of this to support a bit more
code reuse. Src could be a URL or a file and we'd grab the content and output it in
place of the tag. We could support this for any type of template.
> 5- Do we want to allow listing multiple layers in the [resultset
> name=...] arg so that a multiple layers can share the same [resultset]
> block?
Personally I'd prefer one layer, one resultset although I think this is technically
possible.
> 6- How'bout allowing [resultset group=...] as well?
This is just a shortcut method for 5.  I dunno, how often to folks use the same
attributes to present multiple layers?
> Daniel
Steve
