Call for comments - RFC 36
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Nov 5 14:05:08 EST 2007
Comments inline... Steve
>>> On 11/2/2007 at 2:14 PM, in message
<AC5C8D744B56174DB5AE2F3D1A18623F015292C7 at S0-OTT-X2.nrn.nrcan.gc.ca>, "Doyon,
Jean-Francois" <jdoyon at NRCAN.GC.CA> wrote:
> Am I understanding correctly that associating a template with a layer
> would no longer happen, but instead the template would be associated
> with a given outputformat? Does this force the idea of a single
> template per map per format?
Actually you could do either. If the user requests a format (via QUERYFORMAT) that
references an OUTPUTFORMAT then the template (if DRIVER equals TEMPLATE) associated
with that format is used. It's possible that the format has a non-templated output producer
(like GML2/3 or soon KML) too. If the QUERYFORMAT doesn't reference a format object
then we'd fall back to the current setup.
> We have thousands of query templates (a common head and footer, and one
> per queryable layer, with many layers per map, and hundreds of maps, and
> 2 languages), so I'm defintiely interested in this topic :P
> This would be nice because it'd help consolidate query templates into
> fewer files, and more logically per map, as well as allowing multiple
> output formats.
> Have there been any thoughts of adding a cgi parameter to control query
> output format? Or would I use the map_web_queryformat notation? Just a
> thought.
I've thought about it, but figured at this point we'd just expose configuration via
the notation you mention.
> Also, is QUERYFORMAT completely new? It's in webObj, but not mentionned
> in the mapfile reference.
It's 4.8 I think? Another documentation bug, I'll file...
> For me the importance would be to try and minimize the impact on the
> exiting templates and language. If I can just take existing templates
> and merge them into one with a few extra tokens like [resultset] wrapped
> around, then that's not too bad, not fun, but it's all in the name of
> progress :)
You wouldn't have to merge 'em but it sounds like that would make your life
easier in the long run.
> Also, I don't think I'm seeing anything here that precludes keeping both
> ways (using QUERYFORMAT/OUTPUTFORMAT/DRIVER/TEMPLATE and current
> HEADER/LAYER/FOOTER). Might be good to have a bit of overlap where both
> mechanisms exist for a while and then the old way is phased out later?
Overlap was already planned for...
> J.F.
> -----Original Message-----
> From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
> On Behalf Of Steve Lime
> Sent: November 1, 2007 15:09
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-DEV] Call for comments - RFC 36
> Hi all: I (with the help of Tom K.) put together an RFC outlining better
> template support for queries via the CGI interface. Please take a look
> at:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-36/
> Steve
