MapScript C# - Memory Corruption Problem (MapServer 4.10)
Tamas Szekeres
szekerest at GMAIL.COM
Fri Nov 9 14:21:08 EST 2007
Hi Fabio,
Did you experience this problem as well under the context of the ArcSDE driver?
My only problem with this issue is that I coudn't find a way to reproduce that.
Could you describe your use case (code) and your environment in the
corresponding ticket?
http://trac.osgeo.org/mapserver/ticket/2023
I hope we can get forward with this.
Best regards,
Tamas
2007/11/9, Fabio Leme <fabio at geoja.com.br>:
> Hello Hong,
> I'm looking for a solution to my problem and I found your comments at nabble
> Forum.
> I have the same problem that you describe at "MapSCript C#..." message and
> Tamas was replied.
> So, the details are:
> VS 2005 SP1 - .Net 2.0
> mapserver 4.10.0 (C# mapscript)
> Windows XP SP2 (32 bits) (well, i have tested in Windows Server 2003 32 and
> 64 bits and found the same crash)
> Let's go. What do you do to solve the crash ? I'm very discouraged to
> continue using MapServer, because this error.
> When only one user is using the app, it's works fine, but if one more person
> "try" to use, it crashes.
> I detect, after a lot of tests and exaustive observation, the same problem
> that you have in past.
> I don't know what do... where do...
> Can you help me ?
> Thank's a lot,
> Fabio Leme
> São Paulo - Brasil
> View this message in context: http://www.nabble.com/RFC-24-Mapscript-memory-management%3A-call-for-votes-tf3458020.html#a13671879
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
