MapScript C# - Memory Corruption Problem (MapServer 4.10)
Fabio Leme
fabio at GEOJA.COM.BR
Fri Nov 9 12:56:31 EST 2007
Hello Hong,
I'm looking for a solution to my problem and I found your comments at nabble
Forum.
I have the same problem that you describe at "MapSCript C#..." message and
Tamas was replied.
So, the details are:
VS 2005 SP1 - .Net 2.0
mapserver 4.10.0 (C# mapscript)
Windows XP SP2 (32 bits) (well, i have tested in Windows Server 2003 32 and
64 bits and found the same crash)
Let's go. What do you do to solve the crash ? I'm very discouraged to
continue using MapServer, because this error.
When only one user is using the app, it's works fine, but if one more person
"try" to use, it crashes.
I detect, after a lot of tests and exaustive observation, the same problem
that you have in past.
I don't know what do... where do...
Can you help me ?
Thank's a lot,
Fabio Leme
São Paulo - Brasil
View this message in context: http://www.nabble.com/RFC-24-Mapscript-memory-management%3A-call-for-votes-tf3458020.html#a13671879
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
