MS-RFC-35 - Solving the WMS STYLES parameter issue
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Nov 14 07:26:47 EST 2007
One final thought here :) would it be easier to revert to making STYLES
an optional parameters rather than introduce a new user directive, given
that STYLES= will be optional in the future?
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Daniel Morissette
> Sent: 02 November, 2007 10:22 AM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-DEV] MS-RFC-35 - Solving the WMS
> MapServer Dev's,
> I have updated MS-RFC-35
> (http://mapserver.gis.umn.edu/development/rfc/ms-rfc-35)
> based on what I proposed in the exchange we had on the
> initial RFC draft from Frank a little while ago and which
> seemed to be an acceptable compromise:
> "I'd be more in favor of calling the options "pedantic" (with
> its negative connotation) and "permissive", with permissive
> being the default, and for the time being stating in the RFC
> that STYLES is the only parameter that changes behavior in
> permissive mode... and that adding more exceptions in the
> permissive mode should not be taken lightly as this
> encourages misuse of the specs and bloats the code with
> unnecessary exceptions."
> Can you please review the RFC and comment and/or tell us if
> the new approach sounds acceptable to you?
> If we can have consensus on this issue then we could vote to
> adopt the RFC, implement the fix and try to release 5.0.1 in
> the next week or so.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
