Oracle queryByAttributes
Hallgren Johan E jhhal at WMDATA.COM
Sat Nov 24 06:48:01 EST 2007
COOOL
It worked, many thanks
/Johan
___________________________________
Johan Hallgren
WM-data, Logica CMG
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Andreas Albarello
Sent: den 24 november 2007 11:39
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Oracle queryByAttributes
On 24 Nov 2007, at 08:10, Hallgren Johan E wrote:
> Hello
> I have a problem with MapServer 5.0 and Oracle when using
> queryByAttributes.
> Before I could use the following syntax;
> oLayerObj.queryByAttributes(m_MapObj, "OBJECTID", "OBJECTID = 75",
> mapscript.MS_MULTIPLE);
> Now it does not work.
> The debug error is;
> <ERROR>mapscript_csharp<br/>msOracleSpatialLayerWhichShapes():
> OracleSpatial error. Error: ORA-00933: SQL command not properly ended
>  . Query statement: SELECT OBJECTID, OBJECTID, shape FROM (SELECT
> shape, NAMN, OBJECTID FROM SDO_KOMMUN) WHERE  OBJECTID =  OBJECTID =
> 75  AND SDO_FILTER( shape, MDSYS.SDO_GEOMETRY(2003, NULL,
> NULL
> ,MDSYS
> .SDO_ELEM_INFO_ARRAY
> (1,1003,3
> ),MDSYS
> .SDO_ORDINATE_ARRAY
> (1194973,6083188,1973312,7687503) ),'querytype=window') = 'TRUE' .
> Check your data statement.</ERROR>
> Look at the where statement:
> WHERE  OBJECTID =  OBJECTID = 75
Johan,
try this instead:
oLayerObj.queryByAttributes(m_MapObj, NULL, "OBJECTID = 75",
There's no need to pass in the item name as the second argument to
queryByAttributes if you are querying anything but a shape file.
Best regards,
Andreas Albarello
