Oracle queryByAttributes
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Sat Nov 24 05:38:32 EST 2007
On 24 Nov 2007, at 08:10, Hallgren Johan E wrote:
> Hello
> I have a problem with MapServer 5.0 and Oracle when using
> queryByAttributes.
> Before I could use the following syntax;
> oLayerObj.queryByAttributes(m_MapObj, “OBJECTID”, “OBJECTID = 75”,
> mapscript.MS_MULTIPLE);
> Now it does not work.
> The debug error is;
> <ERROR>mapscript_csharp<br/>msOracleSpatialLayerWhichShapes():
> OracleSpatial error. Error: ORA-00933: SQL command not properly ended
> . Query statement: SELECT OBJECTID, OBJECTID, shape FROM (SELECT
> shape, NAMN, OBJECTID FROM SDO_KOMMUN) WHERE OBJECTID = OBJECTID =
> 75 AND SDO_FILTER( shape, MDSYS.SDO_GEOMETRY(2003, NULL,
> NULL
> ,MDSYS
> .SDO_ELEM_INFO_ARRAY
> (1,1003,3
> ),MDSYS
> .SDO_ORDINATE_ARRAY
> (1194973,6083188,1973312,7687503) ),'querytype=window') = 'TRUE' .
> Check your data statement.</ERROR>
> Look at the where statement:
> WHERE OBJECTID = OBJECTID = 75
Johan,
try this instead:
oLayerObj.queryByAttributes(m_MapObj, NULL, “OBJECTID = 75”,
There's no need to pass in the item name as the second argument to
queryByAttributes if you are querying anything but a shape file.
Best regards,
Andreas Albarello
