Oracle queryByAttributes
Hallgren Johan E
jhhal at WMDATA.COM
Sat Nov 24 02:10:06 EST 2007
Hello
I have a problem with MapServer 5.0 and Oracle when using
queryByAttributes.
Before I could use the following syntax;
oLayerObj.queryByAttributes(m_MapObj, "OBJECTID", "OBJECTID = 75",
mapscript.MS_MULTIPLE);
Now it does not work.
The debug error is;
<ERROR>mapscript_csharp<br/>msOracleSpatialLayerWhichShapes():
OracleSpatial error. Error: ORA-00933: SQL command not properly ended
. Query statement: SELECT OBJECTID, OBJECTID, shape FROM (SELECT shape,
NAMN, OBJECTID FROM SDO_KOMMUN) WHERE OBJECTID = OBJECTID = 75 AND
SDO_FILTER( shape, MDSYS.SDO_GEOMETRY(2003, NULL,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(119497
3,6083188,1973312,7687503) ),'querytype=window') = 'TRUE' . Check your
data statement.</ERROR>
Look at the where statement:
Hmmm
I couldn't se other than I send in the correct string but something
happens.
My mapfile look like this:
LAYER
NAME SDO_KOMMUN_O
TYPE POLYGON
STATUS ON
CONNECTION "wmgis/wmgis01 at wmsi1394"
CONNECTIONTYPE oraclespatial
DATA "shape FROM (SELECT shape, NAMN, OBJECTID FROM SDO_KOMMUN)
USING UNIQUE OBJECTID VERSION 10g"
TEMPLATE "c:\temp\template.txt"
DEBUG on
CLASS
OUTLINECOLOR 0 0 255
COLOR 100 100 255
END
END
I'm using mapcript in the csharp environment.
Is there any change here in new 5.0 release?
/Johan
___________________________________
Johan Hallgren
WM-data, Logica CMG
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com
<blocked::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<blocked::https://webaccess.wmdata.com/exchweb/bin/redir.asp?URL=http://
www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20071124/3b45c7ef/attachment.html
