Call for comments -RFC 39
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Nov 23 17:18:49 EST 2007
Yewondwossen Assefa wrote:
> Bart van den Eijnden wrote:
>> Basically I feel the need for a higher object, something like THEME or
>> CLASSIFICATION which groups together a set of classes. This would also
>> make it easier to re-use blocks of classes between several layers
>> without having to copy/paste them. But I can understand if this is
>> outside of the scope of this RFC :-)
> I agree with this, I think this is what Steve raised too and I hope I
> mostly answered to this in that e-mail.
Guys,
Sorry for being late to the game... hopefully it's not too late.
What bugged me initially was the use of text strings as class group
names and the fact that we'd need to do string comparisons to match
class group names for every class evaluation when rendering... leading
to a guaranteed performance hit unless we do something to cache the
results of the string comparisons.
I am also (like Bart) trying to find a way that we could add a higher
level object to group classes instead of using text tags inside the
current classes. That new level of object would correspond to SLD Styles
but since the keyword STYLE is already used for something else in
MapServer we cannot use it here. I was looking for a name for this new
beast and could not find one... until I read Bart's THEME idea... I
think this may be what we need.
Here is an example of what I'm thinking, adapting your RFC-29 example to
use the THEME concept:
LAYER
USETHEME "group1"
THEME
NAME "group1"
CLASS
NAME "name1"
END
CLASS
NAME "name3"
END
END
THEME
NAME "group2"
CLASS
NAME "name2"
END
END
For the time being, classes defined at the top-level of a layer (i.e.
not part of a THEME block) would be part of the "default" theme... this
way old mapfiles continue to work.
Then the day we want to implement the concept of "style table"... err...
I mean "theme table" at the mapfile level, we would allow the definition
of THEMES at the top level in a map, or in an external THEMESET file to
be consistent with SYMBOLSET/FONTSET terminology.
Just some late Friday afternoon thinking... I'm really not sure we got
all bases covered... and this definitely does not map perfectly to the
RST concept that I and Assefa used to work with in a previous life, but
at least that would be closer.
Daniel
Daniel Morissette
http://www.mapgears.com/
