Parallelizing calls to msDrawLayer()
David Fuhry
dfuhry at CS.KENT.EDU
Sat Oct 13 18:37:32 EDT 2007
Tamas,
(responses inline)
Tamas Szekeres wrote:
> David,
> I consider it would be reasonable to establish such mechanism only
> when fetching the data of the layers. Likewise currently the WMS/WFS
> layers are pre-downloaded in parallel before starting to draw the map.
> We should have a similar approach when fetching the other layers as
> well.
Yes, I noticed that WMS/WFS layers are downloaded in parallel before
rendering begins. And I agree, it would be advantageous to extend the
parallel-data-fetching paradigm to all layers.
For non-WMS/WFS layers though, wouldn't it be a significant
disruption to the codebase to add lines 1 and 2 into msDrawMap()?
1. for i=1 to layers.length (in parallel)
2. data[i] = fetch_data_for_layer(i)
3. for i=1 to layers.length (serially)
4. msDrawLayer(data[i])
ISTM that the data-fetching logic might be best left abstracted
beneath msDrawLayer().
> However pre drawing all of the layers and later copying the layers
> over the map image seems to be much less efficient.
Drawing n layers onto n imageObjs is no more expensive than drawing n
layers onto one imageObj, and the former can be parallelized across n
threads.
Although yes, I agree that composition (the "merge" step) will cost
something.
I'm entertaining the idea that the time saved by parallel fetching &
drawing might outweigh the cost of composition.
> When using the parallel fetching approach we should deal only with the
> drivers from the aspect of the thread safety issues.
I might be misunderstanding your point here, but... Rendering a layer
into an independent imageObj should be a pretty independent operation,
and could be made so if it's not now. Glancing at the mapserver
thread-safety FAQ, it seems there are more unsafe & locked components
related to data-fetching drivers than there are for rendering. Which
makes me wonder why you suggest parallelizing the data-fetching but not
the rendering.
Forgive me if I'm playing a bit of devil's advocate here. I'm aware
that non-reentrant functions don't rewrite themselves, and that critical
sections don't surround themselves with mutexes. Surely though, it
ought not to be a tremendous amount amount of work to keep separate
layer-drawing operations from stepping on eachothers' toes?
Thanks,
Dave Fuhry
> Best regards,
> Tamas
> 2007/10/12, David Fuhry <dfuhry at cs.kent.edu>:
>> Has anyone looked into parallelizing the calls to msDraw[Query]Layer()
>> in msDrawMap()?
>> Although I'm new to the codebase, it seems that near the top of
>> msDrawMap(), we could launch a thread for each (non-WMS/WFS) layer,
>> rendering the layer's output onto its own imageObj. Then where we now
>> call msDraw[Query]Layer, wait for thread i to complete, and compose that
>> layer's imageObj onto the map's imageObj.
>> In msDraw[Query]Layer(), critical sections of the mapObj (adding labels
>> to the label cache, for instance) would need to be protected by a mutex.
>> A threaded approach would let some layers get drawn while others are
>> waiting on I/O or for query results, instead of the current serial
>> approach where each layer is drawn in turn. Multiprocessor machines
>> could schedule the threads across all of their cores for simultaneous
>> layer rendering.
>> It seems this could significantly speed up common-case rendering,
>> especially on big machines, for very little overhead. Has there been
>> previous work in this area, or are any major drawbacks evident?
>> Thanks,
>> Dave Fuhry
