MIME type image/wbmp
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Oct 23 09:06:54 EDT 2007
Ah, ok. I wonder how other WMS server packages encoded wbmp as. I
haven't seen wbmp in other servers from an initial search.
FYI in the 1.1.1 DTD, Format is loosely defined as <!ELEMENT Format
(#PCDATA) >, which can be anything.
You're right; image/vnd.wap.wbmp seems to be the definitive way to
define a wbmp MIME type. I'm not sure of the history of image/wbmp in
MapServer or how it got there, however.
I also wonder on how much image/wbmp is used. Would be interesting to
hear other dev's thoughts here.
..Tom
From: Bart van den Eijnden [mailto:bartvde at gmail.com]
Sent: 23 October, 2007 8:30 AM
To: Kralidis,Tom [Burlington]
Cc: MAPSERVER-DEV at lists.umn.edu; Normand Savard
Subject: Re: [UMN_MAPSERVER-DEV] MIME type image/wbmp
Hi Tom,
not the CITE test, a Dutch standardization body named Geonovum
has created their own testsuite to test for the Dutch WMS profile.
That's the one which is complaining about this MIME type.
Best regards,
Bart
On 10/23/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca>
wrote:
Bart,
To confirm, you're using the OGC CITE WMS 1.1.1
testsuite, correct?
Does the CITE test suite suggest "image/vnd.wap.wbmp" at
all?
I've cc'd Normand here who is more familiar with OGC
CITE for WMS, and
tested 5.0-beta5 successfully
(http://www.nabble.com/CITE-WMS-1.1.1-tests-MapServer-5.0-beta5-tf435490
2.html).
..Tom
[mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Bart
van den Eijnden
Sent: 23 October, 2007 2:38 AM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-DEV] MIME type
image/wbmp
Hi list,
in the Netherlands we have a Dutch WMS profile,
with a
test-suite.
One of the things the test suite complains about
is that
image/wbmp is an invalid mimetype.
Looking a bit on internet it seems the MIME type
should be
image/vnd.wap.wbmp or not?
Is this something that Mapserver is willing to
change?
Best regards,
Bart
