vertex simplification
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Sat Oct 27 20:55:02 EDT 2007
Tamas,
I don't think these two things are mutually exclusive. The fact is that
once you get the lines projected into pixel space there is still a need
to remove redundant vertices as Thomas has already identified because it
generates a significant speedup. I think Thomas should move forward on
that front regardless of other steps that might get taken.
Regarding adding douglas-peuker at the raster level, I think that the
jury is not in on that yet. The value of doing this would be because it
can speed up the rendering without a significant impact to the display
quality. I think Thomas needs to perform some test in this area and
report on the findings.
There are advantages to doing simplification at the source level and
potentially caching the source data, in that there is less data to move
into mapserver and less data to manipulate and this has some savings
that can be pretty big depending on  a lot of variables. But once that
data or any data is in pixel space there are a whole other set of
optimizations that can/need to be applied regardless of the source data
that can speed up specifically the rasterizing task and this is what
Thomas is looking at.
So we should get champions to move both fronts forward.
Best regards,
   -Steve
Tamas Szekeres wrote:
> Thomas,
> I think this kind of feature preprocessing task should not be bound
> tightly to the rendering process and should be treated differently.
> The concept around MS-RFC-22 (
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-22a ) is a kind of
> preliminary invocation for satisfying this need.
> We should also allow the user to define the desired processing
> pipeline along with some caching to prevent from doing the same
> operation twice in the further drawings or among the layers if
> possible.
> The concept out there would also allow to drag in the capabilities of
> the GEOS library to make more functions available like the
> Douglas-Peuker simplifier as it happens.
> In many cases however it might be desirable to make the simplification
> at the data source to decrease the amount of data to be retrieved.
> Best regards,
> Tamas
> 2007/10/27, thomas bonfort <thomas.bonfort at gmail.com>:
>> hi all,
>> I'm looking into adding some vertex simplification at the image level,
>> for the time being limited to the agg renderer. I've got two questions
>> I'd like to have feedback on:
>> * it's very easy to add a local simplification, by removing vertexes
>> in a linestring that are closer than some threshold to their preceding
>> vertex. I'm getting nice speedups by mimicking what's currently (more
>> or less implicitely) done with gd, by removing vertexes that fall in
>> the same pixel than its predecessor (of course these speedups would
>> only happen for complex line layers. I'm currently testing with the
>> canadian road data mentionned in
>> http://wiki.osgeo.org/index.php/FOSS4G2007_IntegrationShowcase). I
>> know agg is all about subpixel accuracy and such, but I'd think this
>> behaviour could be enabled by default ( as in this case the maximum
>> error for a vertex is less than a pixel)
>> * is anyone interested in having a global and tunable vertex
>> simplification functionality. I don't think it would be too much work
>> work to implement a douglas-peuker line generalisation algorithm, that
>> could be turned on and tunable with a new mapfile keyword. That's
>> basically doing what postgis' SIMPLIFY can already do, except this
>> would be done in pixel coordinates, and therefore would not have to be
>> tuned w.r.t. scale.
>> thomas
