[mapserver-dev] RFC: GMaps API for mapserv
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Apr 11 10:52:44 EDT 2008
I was kinda wondering if there was a way to address these using OUTPUTFORMATs. If one could
encapsulate the number of levels, reference extent and projection in one of those then a URL
might look like:
&mode=tile&map.imagetype=GMap&more parameters...
We could even set a default tiled outputformat, probably GMap.
Steve
>>> On 4/10/2008 at 11:48 PM, in message
<30fe546d0804102148v5820d18bha58600e36217329 at mail.gmail.com>, "Paul Ramsey"
<pramsey at cleverelephant.ca> wrote:
> All,
> Attached find a revised RFC, per some of the feedback I have received.
> I am a little loath to give up the simpler URL syntax from the
> previous RFC (one new mode, one new parameter) so I would like to hear
> back if you feel the gains in "futureness" outweigh the simplicity of
> the first draft. YAGNI says I should just do the Google version and
> let the future take care of itself.
> Paul
