[mapserver-dev] Tile Access API
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Apr 16 09:46:36 EDT 2008
+1 for WEB.METADATA.ALLOWED_SERVICES
- comma separated
- no version specificity implies all versions, mind you, do we want to
get this fine grained? Providers (usually) want to support as many
versions as possible of an interface standard.
..Tom
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Steve Lime
> Sent: 16 April, 2008 9:41 AM
> To: mapserver-dev at lists.osgeo.org; dmorissette at mapgears.com
> Subject: Re: [mapserver-dev] Tile Access API
> I think this is a good idea as well, one that we've talked
> about in the past with regards to OGC services. Perhaps an
> explicit MAP-level tag or WEB-level metadata with a delimited
> list of supported services:
> ALLOWED_SERVICES 'WMS,TILES,WFS:1.0;1.1'
> Steve
> >>> Daniel Morissette <dmorissette at mapgears.com> 04/16/08 7:32 AM >>>
> Paul Ramsey wrote:
> > The barn door is already wide open on this one, and is
> already being
> > traversed, but clients like ArcExplorer over WMS, Google Earth over
> > WMS, and as you note OpenLayers over WMS. You put up a
> server, egads,
> > people use it!
> > A tile API is actually an improvement, since it's at least
> trivially
> > easy to get proxy caching behavior within the constrained URL space
> > provided by the tiling system.
> You've got good points, but I wonder if we should do
> something to protect our users who are not aware of the risk
> of their servers getting overloaded by those clients and
> limit the damage by having this feature disabled by default.
> If someone enables it then they need to understand the risk
> and live with it, but at least those who are not prepared to
> deal with that kind of load are not exposed by default.
> I guess if we follow this logic we should disable all OGC web
> service interfaces by default as well... maybe we should?
> What do you all think?
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
