[mapserver-dev] Tile Access API
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Apr 16 11:02:53 EDT 2008
Sometimes I'd like to be able to disable old versions. I'm thinking of WFS specifically given the issues
with GML2 and GML3. Some application schemas will only want GML3.
Steve
>>> On 4/16/2008 at 8:46 AM, in message
<2DC5CCA14756424BBBEE8B4B2E4A682F036CF22C at ecburexch1.ontario.int.ec.gc.ca>,
"Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
> +1 for WEB.METADATA.ALLOWED_SERVICES
>  - comma separated
>  - no version specificity implies all versions, mind you, do we want to
> get this fine grained?  Providers (usually) want to support as many
> versions as possible of an interface standard.
> ..Tom
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Steve Lime
>> Sent: 16 April, 2008 9:41 AM
>> To: mapserver-dev at lists.osgeo.org; dmorissette at mapgears.com
>> Subject: Re: [mapserver-dev] Tile Access API
>> I think this is a good idea as well, one that we've talked
>> about in the past with regards to OGC services. Perhaps an
>> explicit MAP-level tag or WEB-level metadata with a delimited
>> list of supported services:
>>   ALLOWED_SERVICES 'WMS,TILES,WFS:1.0;1.1'
>> Steve
>> >>> Daniel Morissette <dmorissette at mapgears.com> 04/16/08 7:32 AM >>>
>> Paul Ramsey wrote:
>> > The barn door is already wide open on this one, and is
>> already being
>> > traversed, but clients like ArcExplorer over WMS, Google Earth over
>> > WMS, and as you note OpenLayers over WMS.  You put up a
>> server, egads,
>> > people use it!
>> > A tile API is actually an improvement, since it's at least
>> trivially
>> > easy to get proxy caching behavior within the constrained URL space
>> > provided by the tiling system.
>> You've got good points, but I wonder if we should do
>> something to protect our users who are not aware of the risk
>> of their servers getting overloaded by those clients and
>> limit the damage by having this feature disabled by default.
>> If someone enables it then they need to understand the risk
>> and live with it, but at least those who are not prepared to
>> deal with that kind of load are not exposed by default.
>> I guess if we follow this logic we should disable all OGC web
>> service interfaces by default as well... maybe we should?
>> What do you all think?
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
