[mapserver-dev] RFC 44
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Apr 24 20:37:23 EDT 2008
Paul,
This is a great idea! I can think of one minor (I think) thing you need
to do for this. With tileindexes, if a .prj file exists then that would
be used for ALL the files represented by the tileindex. This would avoid
having to look at individual .prj which would be a preformance boost.
And I'm not sure it makes any sense to have a tileindex with mixed
projection without at least projecting the extents into the srs of the
tileindex - I think we don't want to go there anyway.
This might mean that tile4ms should have an optional srs parameter
and/or read and verify that all files added to the tileindex are from
the same srs if they have .prj files.
Thoughts?
-Steve
Paul Ramsey wrote:
> Comments appreciated, in particular regarding where in the lifecycle
> this should be inserted:
> MS RFC 44: Automatic Projection Configuration for Layers
> :Date: 2008/04/24
> :Author: Paul Ramsey
> :Contact: pramsey at cleverelephant.ca
> :Last Edited: 2008/04/24
> :Status: Open
> Overview
> In order to do reprojection, Mapserver currently requires a PROJECTION
> block in the MAP file and in *every* LAYER block. However, many (or
> even most) layer types in Mapserver support retrieving SRS
> information, from WKT files (like shape files .prj) or from tables
> (like PostGIS spatial_ref_sys) or from the files themselves (like
> GeoTIFF).
> If the virtual layer API is extended to support automatic projection
> configuration, new users can enjoy transparent support for
> projections, while existing behavior and performance can be preserved
> via the PROJECTION block. Layers that cannot support automatic
> projection will still require PROJECTION blocks, and map files that
> have PROJECTION blocks can use those to avoid the overhead of
> automatic projection configuration.
> Technical Solution
> We will add a new function to the layer->vtable, LayerLoadProjection.
> *NEEDED:* where do we call LayerLoadProjection from for best effect?
> LayerLoadProjection will:
> * Default to no-op and MS_SUCCESS
> * Load a projection if one is available, into layer->projection and
> return MS_SUCCESS
> * Leave layer->projection alone and return MS_SUCCESS ASAP if no
> projection is available
> * return MS_FAILURE in the event of something catastrophic (OOM, etc)
> during load
> Mapscript Implications
> See NEEDED above.
> If LayerLoadProjection is called early in the lifecycle (during map
> load, for example) then Mapscript can potentially read and over-ride
> the projectionObj, which is good. If it is called late in the
> lifecycle, then Mapscript cannot read the value, though it can still
> over-ride it, simply by ensuring that a projectionObj with arguments
> is set.
> Files Affected
> maplayer.c
> mapshape.c (first implementation)
> map*.c (eventually all connection types that support automatic CRS discovery)
> * Documentation will be updated to reflect the new feature
> * Mapserver CGI Reference
> * Test suite will be updated to exercise the new features
> * Frank Warmerdam has volunteered to do this
> Performance Implications
> PROJECTION blocks are faster than reading files and database tables
> for this information. This feature will be slower than PROJECTION
> blocks. The performance advantages of PROJECTION blocks will have to
> be documented and highlighted.
> In future phases, some performance issues can be shaved away by
> starting to cache projection information so that FCGI implementations
> do not have to re-read projection information or re-instantiate
> projection objects ever.
> Backwards Compatibility Issues
> Installations with bad data (mismatched data and prj information)
> might end up with an unexpected breakage. Installations with working
> PROJECTION blocks already in place will have no problems.
> Bug ID
> Not yet.
> Voting History
> No vote yet.
> References
> None.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
