[mapserver-dev] Performance Patch
Jeff McKenna jeffmckenna at gmail.com
Sat Apr 26 12:20:58 EDT 2008
Paul there seems to be some quirks with the patch & MSVC (with r7531) :
mapshape.c(1062) : error C2143: syntax error : missing ';' before 'type'
mapshape.c(1066) : error C2065: 'buffer' : undeclared identifier
mapshape.c(1066) : warning C4022: 'fread' : pointer mismatch for
actual paramete
r 1
mapshape.c(1070) : error C2143: syntax error : missing ';' before 'type'
mapshape.c(1071) : error C2065: 'i' : undeclared identifier
mapshape.c(1078) : warning C4022: 'memcpy' : pointer mismatch for
actual paramet
er 2
mapshape.c(1079) : warning C4022: 'memcpy' : pointer mismatch for
actual paramet
er 2
mapshape.c(1106) : error C2143: syntax error : missing ';' before 'type'
mapshape.c(1131) : error C2143: syntax error : missing ';' before 'type'
mapshape.c(1133) : error C2065: 'shxBufferPage' : undeclared identifier
mapshape.c(1147) : error C2143: syntax error : missing ';' before 'type'
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
8\VC\BIN\c
l.EXE"' : return code '0x2'
Stop.
-jeff
On 25-Apr-08, at 5:12 PM, Paul Ramsey wrote:
> So, for my first commit, I'd like to apply the very cool shape file
> performance patch :)
> http://trac.osgeo.org/mapserver/ticket/2282
> However, as far as I know only Steve has tested it.  Surely someone
> else has an existing map file that uses largish shape files and can do
> a before-and-after?  Or has an app that does shapefile writing in
> mapscript?
> Paul
