[mapserver-dev] Performance Patch
Paul Ramsey
pramsey at cleverelephant.ca
Sat Apr 26 17:51:29 EDT 2008
Yes, MSVC is stricter than GCC on where you declare your variables, so
it's failing compile. Anyone know a magic flag I can set in GCC to
make it strict also? Easier to find these if my compiler complained
than kicking over the buildbot repeatedly...
Thanks Jeff,
P.
On Sat, Apr 26, 2008 at 9:20 AM, Jeff McKenna <jeffmckenna at gmail.com> wrote:
> Paul there seems to be some quirks with the patch & MSVC (with r7531) :
> mapshape.c(1062) : error C2143: syntax error : missing ';' before 'type'
> mapshape.c(1066) : error C2065: 'buffer' : undeclared identifier
> mapshape.c(1066) : warning C4022: 'fread' : pointer mismatch for actual
> paramete
> r 1
> mapshape.c(1070) : error C2143: syntax error : missing ';' before 'type'
> mapshape.c(1071) : error C2065: 'i' : undeclared identifier
> mapshape.c(1078) : warning C4022: 'memcpy' : pointer mismatch for actual
> paramet
> er 2
> mapshape.c(1079) : warning C4022: 'memcpy' : pointer mismatch for actual
> paramet
> er 2
> mapshape.c(1106) : error C2143: syntax error : missing ';' before 'type'
> mapshape.c(1131) : error C2143: syntax error : missing ';' before 'type'
> mapshape.c(1133) : error C2065: 'shxBufferPage' : undeclared identifier
> mapshape.c(1147) : error C2143: syntax error : missing ';' before 'type'
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 8\VC\BIN\c
> l.EXE"' : return code '0x2'
> Stop.
> -jeff
> On 25-Apr-08, at 5:12 PM, Paul Ramsey wrote:
> > So, for my first commit, I'd like to apply the very cool shape file
> > performance patch :)
> > http://trac.osgeo.org/mapserver/ticket/2282
> > However, as far as I know only Steve has tested it. Surely someone
> > else has an existing map file that uses largish shape files and can do
> > a before-and-after? Or has an app that does shapefile writing in
> > mapscript?
> > Paul
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
