[mapserver-dev] Performance Patch
Jeff McKenna jeffmckenna at gmail.com
Mon Apr 28 10:48:54 EDT 2008
Here are my results with testing the shp performance patch:
test shapefile: StatsCan Road Network (1.8 mil records)
test method: shp2img with -map_debug 3
test environment: windows
on Extents showing 162 features only:
ms5.0.2
- no index
msDrawMap(): Layer 0 (statscan roads), 35.672s
- indexed
msDrawMap(): Layer 0 (statscan roads), 1.122s
SVN r7539
- no index
msDrawMap(): Layer 0 (statscan roads), 34.780s
- indexed
msDrawMap(): Layer 0 (statscan roads), 0.210s
-jeff
> However, as far as I know only Steve has tested it.  Surely someone
> else has an existing map file that uses largish shape files and can do
> a before-and-after?  Or has an app that does shapefile writing in
> mapscript?
> Paul
