[mapserver-dev] Performance Patch
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 28 15:10:02 EDT 2008
Thanks Jeff, good to know it works on Windoze too!
P
On Mon, Apr 28, 2008 at 7:48 AM, Jeff McKenna <jeffmckenna at gmail.com> wrote:
> Here are my results with testing the shp performance patch:
>  test shapefile: StatsCan Road Network (1.8 mil records)
>  test method: shp2img with -map_debug 3
>  test environment: windows
>  on Extents showing 162 features only:
>  ms5.0.2
>  - no index
>  msDrawMap(): Layer 0 (statscan roads), 35.672s
>  - indexed
>  msDrawMap(): Layer 0 (statscan roads), 1.122s
>  SVN r7539
>  - no index
>  msDrawMap(): Layer 0 (statscan roads), 34.780s
>  - indexed
>  msDrawMap(): Layer 0 (statscan roads), 0.210s
>  -jeff
> > However, as far as I know only Steve has tested it.  Surely someone
> > else has an existing map file that uses largish shape files and can do
> > a before-and-after?  Or has an app that does shapefile writing in
> > mapscript?
> > Paul
>  _______________________________________________
>  mapserver-dev mailing list
>  mapserver-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapserver-dev
