[mapserver-dev] OT: Help is configure
Daniel Morissette dmorissette at mapgears.com
Wed Aug 20 11:41:32 EDT 2008
You could look at the way the Apache version string is parsed in
MapServer's configure.in.
To mkae this simpler in the future, perhaps it's time to add
MS_VERSION_NUM to mapserver.h similar to what we have in GDAL, e.g.
#ifndef MS_VERSION_MAJOR
#  define MS_VERSION_MAJOR    5
#  define MS_VERSION_MINOR    2
#  define MS_VERSION_REV      0
#endif
#ifndef MS_VERSION_NUM
#  define MS_VERSION_NUM
(MS_VERSION_MAJOR*10000+MS_VERSION_MINOR*100+MS_VERSION_REV)
#endif
Then your code could use
#if MS_VERSION_NUM >= 50200 /* Use OGR Style C API */
If you file a ticket and there are no objections then I'll add this. We
could also backport to 5.2.1 to make this useful immediately.
Daniel
Stephen Woodbridge wrote:
> Hi all,
> Could someone familiar with configure scripts help me with how to detect
> which version of code I'm trying configure and build with. I have a C
> application that links with mapserver.a and occasionally I run into
> changes like below that I need to detect and set an appropriate DEFINE
> so I can code around this if #ifdef blocks.
> 5.0.3
> int msQueryByPoint(mapObj *map, int qlayer, int mode, pointObj p, double
> buffer)
> 5.2.0
> buffer, int maxresults)
> I have a very basic automake, autoconf script that works ok, but I need
> to figure out how to add code to check for the above or to check if the
> mapserver version is 5.2.0 or greater.
> Any help, suggestions or pointers would be appreciated.
> Thanks,
>   -Steve W
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
