[mapserver-dev] PHP_MapScript - set opacity of a styleObj
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Wed Aug 27 01:53:58 EDT 2008
Hello devs,
I'm just wondering if I'm missing anything (since the online
documentation claims to be out-of-date). I'm trying to create a new
layer in a PHP_MapScript map object that has opacity set in a styleObj.
But when I execute $oStyle->set("opacity",50), I get an error message
saying "Property 'opacity' does not exist in this object.". The same
happens for transparency. Is there a different way I should be doing this?
Since style-level opacity is a new feature, I'm guessing it hasn't made
its way into mapscript yet? If that is the case, what would be needed
to add this, and/or is there a workaround I that can use instead? The
only alternative I can imagine at this point is to save the map object
to a temporary mapfile, write the new layers as text in the mapfile,
then read it back into a new map object. Is that my best option?
Thanks for any suggestions,
Mike
