[mapserver-dev] ms rfc 48: adding a type keyword to the styleblock
thomas bonfort
thomas.bonfort at gmail.com
Thu Dec 4 04:01:27 EST 2008
On Wed, Dec 3, 2008 at 11:34, Tamas Szekeres <szekerest at gmail.com> wrote:
> 2008/12/3 thomas bonfort <thomas.bonfort at gmail.com>
>> I'd like to call for vote on this rfc tomorrow, so please chime in
>> before that if you have any comments.
> Thomas,
> It seems OK from my side.
> Could you add the corresponding getters/setters as explicit functions (like
> msGetGeometryTransform/msSetGeometryTransform) which could easily be bound
> to the mapscript interface? I guess you might want to preprocess the
> expression inside the setter instead of every time when drawing the the map.
Tamas,
I'll add the getters and setters. Do you think the getter should
return the expression string, or the #define'd transformation code
itself ?
regards,
thomas
