[mapserver-dev] ms rfc 48: adding a type keyword to the styleblock
Tamas Szekeres szekerest at gmail.com
Thu Dec 4 06:21:42 EST 2008
2008/12/4 thomas bonfort <thomas.bonfort at gmail.com>
> I'll add the getters and setters. Do you think the getter should
> return the expression string, or the #define'd transformation code
> itself ?
I think the getter should return the same (or similar) string as specified
in the getter function or in the mapfile.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081204/b3b92fc8/attachment.html
