[mapserver-dev] ms rfc 48: adding a type keyword to the styleblock
Tamas Szekeres
szekerest at gmail.com
Thu Dec 4 06:27:52 EST 2008
Um, so I wanted to say.
"I think the getter should return the same (or similar) string as specified
in the setter function or in the mapfile."
Tamas
2008/12/4 Tamas Szekeres <szekerest at gmail.com>
> 2008/12/4 thomas bonfort <thomas.bonfort at gmail.com>
>> I'll add the getters and setters. Do you think the getter should
>> return the expression string, or the #define'd transformation code
>> itself ?
> in the getter function or in the mapfile.
> Best regards,
> Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081204/a7338e9e/attachment.html
