[mapserver-dev] RFC49: mapfile simplifications and
symbologyenhancements
thomas bonfort
thomas.bonfort at gmail.com
Thu Dec 4 06:17:34 EST 2008
karsten, if I understant your request correctly, MapServer already has that:
STYLE
SYMBOL "circle"
SIZE [population]
MINSIZE 3
MAXSIZE 20
END
you'll probably want to preprocess the [population] in your data
request (to add steps, or scaling)
regards,
thomas
On Thu, Dec 4, 2008 at 11:45, Karsten Hoffmann
<khoffmann at igf.uni-osnabrueck.de> wrote:
> Dear developers,
> I would like to ask for another feature which could be perhaps included in
> this RFC.
> Since version 5.2 it's possible to bind the size of pie charts to an
> attribute (https://trac.osgeo.org/mapserver/ticket/2136):
> PROCESSING "CHART_SIZE_RANGE=itemname minsize maxsize minval maxval"
> This would also be useful for point symbols as simple diagrams without
> slices or bars. The idea is to have a symbol, let's say a filled circle or
> square, which varies continuously in size. The size is bound to an attribute
> for example the absolute number of habitants of different countries.
> This would be a useful feature for thematic mapping. Is it possible to
> implement this?
> Best regards
> Karsten Hoffmann
> -----Ursprüngliche Nachricht-----
> Von: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von thomas bonfort
> Gesendet: Donnerstag, 4. Dezember 2008 11:18
> An: mapserver-dev Mailing List
> Betreff: [mapserver-dev] RFC49: mapfile simplifications and
> Hi,
> Not sure if the changes warrant a full blown RFC, but as there quite a
> number of them I've regrouped them.
> http://trac.osgeo.org/mapserver/browser/trunk/docs/development/rfc/ms-rfc-49
> .txt
> These changes are/were all in RFC45, but were extracted to keep things
> moving on as some of the stuff in rfc45 lacks funding in the near
> future.
> You can see it in action here on openstreetmap data:
> http://mapserverosm.s3.amazonaws.com/parisosm.html
> nothing that's impossible to do with the current mapfile keywords
> (except for polygon label placement, and thin lines thanks to
> fractional size/widths), but the mapfile maintainance and creation is
> greatly simplified, as e.g. roads are mostly defined with a single
> class whatever the scale (using a combination of sizeunits at the
> layer level, and min/max width and min/max scale at the style level)
> regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
