AW: [mapserver-dev] RFC49: mapfile simplifications
andsymbologyenhancements
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Dec 4 20:22:04 EST 2008
MapServer's interpretation of size through an attribute binding is
literal. That is, the value
in the column is used as the size in pixels. Since you set a max scale
it makes sense you
see all size 43.
In that case your suggestion makes sense although I'm not sure the best
way to implement.
I don't think strictly following the charting syntax makes sense since
we'd then have two ways
to bind attributes which would get confusing. Any ideas?
Steve
>>> "Karsten Hoffmann" <khoffmann at igf.uni-osnabrueck.de> 12/04/08 5:59
AM >>>
Hi Thomas,
I’m not sure if I understand what you mean.
I tried your proposition with Mapserver 5.2. But all circles have the
same
size (43 pixel):
LAYER
NAME population
TYPE POINT
STATUS default
DATA Lan_point.shp
CLASS
NAME 'Population'
STYLE
SYMBOL 'circle'
SIZE [poptotal]
MINSIZE 18
MAXSIZE 43
OUTLINECOLOR 0 0 0
COLOR 0 0 255
END
END
END
The sizes of the circles should vary depending on the number of
habitants. I
don’t want to preprocess the population data. At the moment I calculate
the
sizes of the circles by myself and write them in a new field (pop_size)
in
the attribute table.
The Style is then:
STYLE
SYMBOL 'circle'
SIZE [pop_size]
OUTLINECOLOR 0 0 0
COLOR 0 0 255
END
The population varies from around 5000 to 30000 habitants. The sizes of
the
circles should vary from 18 to 43.
With a Chart-Layer it is very comfortable to define this:
PROCESSING "CHART_SIZE_RANGE=poptotal 18 43 5000 30000"
But I don’t want to have a pie chart with slices here just a simple
filled
circle.
Best,
Karsten
-----Ursprüngliche Nachricht-----
Von: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Gesendet: Donnerstag, 4. Dezember 2008 12:18
An: Karsten Hoffmann
Cc: mapserver-dev Mailing List
Betreff: Re: [mapserver-dev] RFC49: mapfile simplifications and
karsten, if I understant your request correctly, MapServer already has
that:
STYLE
SYMBOL "circle"
SIZE [population]
MINSIZE 3
MAXSIZE 20
END
you'll probably want to preprocess the [population] in your data
request (to add steps, or scaling)
regards,
thomas
On Thu, Dec 4, 2008 at 11:45, Karsten Hoffmann
<khoffmann at igf.uni-osnabrueck.de> wrote:
> Dear developers,
> I would like to ask for another feature which could be perhaps
included in
> this RFC.
> Since version 5.2 it's possible to bind the size of pie charts to an
> attribute (https://trac.osgeo.org/mapserver/ticket/2136):
> PROCESSING "CHART_SIZE_RANGE=itemname minsize maxsize minval maxval"
> This would also be useful for point symbols as simple diagrams without
> slices or bars. The idea is to have a symbol, let's say a filled
circle or
> square, which varies continuously in size. The size is bound to an
attribute
> for example the absolute number of habitants of different countries.
> This would be a useful feature for thematic mapping. Is it possible to
> implement this?
> Best regards
> Karsten Hoffmann
> Von: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von thomas
bonfort
> Gesendet: Donnerstag, 4. Dezember 2008 11:18
> An: mapserver-dev Mailing List
> Betreff: [mapserver-dev] RFC49: mapfile simplifications and
> Hi,
> Not sure if the changes warrant a full blown RFC, but as there quite a
> number of them I've regrouped them.
http://trac.osgeo.org/mapserver/browser/trunk/docs/development/rfc/ms-rfc-49
> .txt
> These changes are/were all in RFC45, but were extracted to keep things
> moving on as some of the stuff in rfc45 lacks funding in the near
> future.
> You can see it in action here on openstreetmap data:
> http://mapserverosm.s3.amazonaws.com/parisosm.html
> nothing that's impossible to do with the current mapfile keywords
>> greatly simplified, as e.g. roads are mostly defined with a single
> class whatever the scale (using a combination of sizeunits at the
> layer level, and min/max width and min/max scale at the style level)
> regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
