[mapserver-dev] How to reset the projection object for
	layerObjandmapObj
    Steve Lime
    Steve.Lime at dnr.state.mn.us
    Mon Dec  8 18:10:24 EST 2008
I'll defer to Daniel or Frank on that one...
Steve
>>> On 12/7/2008 at 2:37 PM, in message
<f3b73b7d0812071237r634cbb8dja2d446f4ade5aeed at mail.gmail.com>, "Tamas Szekeres"
<szekerest at gmail.com> wrote:
> Steve,
> It seems setProjection("+AUTO") is doing something like I was wishing for.
> However I don't see in the documentation the desired purpose of this
> setting;
> http://mapserver.gis.umn.edu/docs/reference/mapfile/projection
> Could you confirm whether the purpose of "+AUTO" is to reset the projection
> into an unspecified state?
> Best regards,
> Tamas
> 2008/12/2 Steve Lime <Steve.Lime at dnr.state.mn.us>
>> As far as I know you're correct. Handling the null would seem an elegant
>> solution
>> if it can be done.
>> Steve
>> >>> "Tamas Szekeres" <szekerest at gmail.com> 12/02/08 7:59 AM >>>
>> Hi Devs,
>> Am I right that currently we don't have the option to reset the projection
>> object for  layerObj and the mapObj by using the SWIG interface?
>> I just wanted to  revert this object into the same state as if it was
>> created without specifying the projection.
>> Using setProjection(null) doesn't seem to be a supported option since
>> msLoadProjectionString doesn't handle the null argument value.
>> If you don't know about a workaround either, then I'm keen to modify
>> msLoadProjectionString in order to handle this option.
>> Best regards,
>> Tamas
