[mapserver-dev] How to reset the projection object for layerObj
andmapObj
Tamas Szekeres
szekerest at gmail.com
Sun Dec 7 15:37:32 EST 2008
Steve,
It seems setProjection("+AUTO") is doing something like I was wishing for.
However I don't see in the documentation the desired purpose of this
setting;
http://mapserver.gis.umn.edu/docs/reference/mapfile/projection
Could you confirm whether the purpose of "+AUTO" is to reset the projection
into an unspecified state?
Best regards,
Tamas
2008/12/2 Steve Lime <Steve.Lime at dnr.state.mn.us>
> As far as I know you're correct. Handling the null would seem an elegant
> solution
> if it can be done.
> Steve
> >>> "Tamas Szekeres" <szekerest at gmail.com> 12/02/08 7:59 AM >>>
> Hi Devs,
> Am I right that currently we don't have the option to reset the projection
> object for layerObj and the mapObj by using the SWIG interface?
> I just wanted to revert this object into the same state as if it was
> created without specifying the projection.
> Using setProjection(null) doesn't seem to be a supported option since
> msLoadProjectionString doesn't handle the null argument value.
> If you don't know about a workaround either, then I'm keen to modify
> msLoadProjectionString in order to handle this option.
> Best regards,
> Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081207/768d0be8/attachment.html
