[mapserver-dev] plugin renderer support status update
Steve Lime
Steve.Lime at DNR.State.MN.US
Fri Dec 26 10:30:09 EST 2008
A nice Christmas present indeed! You'll have to let devs know how we
can help. Can the OpenGL implementation use this approach?
I'm not sure what your time line looks like but I would think an addition
like this plus the other things in the queue at the moment hint more at a
6.0 release than 5.4. Curious what others think...
Congratulations on the work so far, it looks terrific!
Steve
>>> On 12/25/2008 at 3:53 AM, in message
<d2b988930812250153r74062fbat77969685e10a79e8 at mail.gmail.com>, "thomas bonfort"
<thomas.bonfort at gmail.com> wrote:
> hi guys, merry christmas to you
> I've been spending some of my holiday time on implementing "plugin"
> rendering for mapserver vector handling, and applied this on adding a
> cairo backend.
> some really pre-alpha code has been checked into the "graphics" sandbox:
> * support for cairo output driver (currently png, svg and pdf)
> * "plugin" renderer support (currently only cairo uses it)
> * text layout is managed by pango for the cairo rendering (should
> open up a nice couple of things, notably for non-ascii text support)
> I still have quite a lot of work to do to support the full mapfile
> possibilities (follow text, marker/shield/filling symbols, transparent
> layers, the list goes on...)
> some samples here:
> * reference agg output: http://terriscope.fr/ms_tmp/osmagg.png
> * cairo png: http://terriscope.fr/ms_tmp/osmcairo.png
> * cairo svg: http://terriscope.fr/ms_tmp/svgfile.svg
> * cairo pdf: http://terriscope.fr/ms_tmp/pdffile.pdf
> what's really cool is that the core cairo rendering code weighs in at
> under 300 lines, thanks to the plugin approach.
> cheers,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
