[mapserver-dev] MapScript multithreading performance
Tamas Szekeres
szekerest at gmail.com
Mon Feb 11 10:32:04 EST 2008
Adrian,
I'm not aware of much locking around the drawing code of it's own.
This might be another issue I think. Would you share your mapfile and
the C# code you test with?
How do you detect which part of the code causes the problem and which not?
I expect your problem reported might be related to some operations
requiring heavy resource access (eg. file loads during epsg lookups).
Have you monitored your disk access that might also be optimized?
I'm not sure if the processor usage is the perfect measure of the
efficiency of the application either.
Best regards,
Tamas
2008/2/11, adrian kruk <adrian.kruk at gmail.com>:
> Hi,
> I did some multithreading performance tests using C# mapscript (We've
> discussed about safety and performance before)
> I have run 200 threads running simultanously and performing actions like:
> create mapObject, zoom, pan, query, draw, etc
> Testing application environment:
> -4processors server (Intel Xeon E5320)
> -Win2003EE+SP3
> -4GM RAM
> -MapScript 5.1-DEV from
> http://www.coordinatesolutions.com/download/ASPNET20Sample_50.zip
> -1GB data in shapefiles on RAID
> I expected performance problems with parsing mapfile (static variables,
> locks). But there were no problems with it.
> During parsing mapfile by 200 threads processors was used in 98-100%. So it
> is perfect result.
> But, I find problem probably with draw method. Each thread was executing
> methods on its own map object like:
> drawLegend, drawScalebar, queryByAttributes, zoomPoint, setExtent, Draw.
> During running test application, and executing those methods, processors was
> used in 25-35% ONLY (25% - one processor).
> Its very poor result. I guess that problem may be related with using locks
> in drawing process{ imageObj img = map.draw() }, which takes much more time
> than other mapObject methods.
> How to improve performance? It is hard to fix it?
> Regards,
> Adrian Kruk,
> infovidematrix.pl
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
