[mapserver-dev] MapScript multithreading performance
Frank Warmerdam
warmerdam at pobox.com
Mon Feb 11 10:39:24 EST 2008
Tamas Szekeres wrote:
> Adrian,
> I'm not aware of much locking around the drawing code of it's own.
> This might be another issue I think. Would you share your mapfile and
> the C# code you test with?
> How do you detect which part of the code causes the problem and which not?
> I expect your problem reported might be related to some operations
> requiring heavy resource access (eg. file loads during epsg lookups).
> Have you monitored your disk access that might also be optimized?
> I'm not sure if the processor usage is the perfect measure of the
> efficiency of the application either.
Adrian,
I agree with Tamas - we don't have enough information to give an informed
answer.
I will note that DrawMap() has to access the feature data, and so is quite
subject to feature access lock contention. For instance, if you are using
CONNECTIONTYPE OGR and MapServer 5 there is a big lock around OGR. That means
only one drawing thread at a time can be in OGR fetching data which is often
the dominant time consumer.
So, providing details of your datasource would be helpful. But really,
you need a way of interrupting your threads to see where they are blocked
in some fashion to get a better sense of what is the hold up.
I will say, that I'm unaware of any locks around the rendering work itself,
at least with the GD vector rendering code. So for actual rendering intensive
applications, multi-threading should give good cpu utilization.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
