[mapserver-dev] Is there a size limit on ImageMaps, and if so can I increase it?
Bob Bruce Bob.Bruce at shaw.ca
Mon Feb 25 11:15:54 EST 2008
Daniel:
              I am using version 4.10.2 . Previously I had this working in a version of MapServer in 2005 and it is still working to this day at www.themuralsofwinnipeg.com/Mpages/indexMuralsMap.php with this old version (if you select the South-Portage neighbourhood it works fine). Now I wanted to upgrade to version 4 but wasn't ready to take the leap to version 5. Do you think that I need to upgrade to version 5 and rebuild MapServer etc.?
thanks for getting back to me,
                                                Bob Bruce
----- Original Message -----
From: Daniel Morissette <dmorissette at mapgears.com>
Date: Monday, February 25, 2008 9:29 am
Subject: Re: [mapserver-dev] Is there a size limit on ImageMaps, and if so can I increase it?
To: Bob.Bruce at pobox.com
Cc: 'MapServer Dev Mailing List' <mapserver-dev at lists.osgeo.org>, "'Bob Buchanan @ The Murals of Winnipeg'" <Bob.Buchanan at TheMuralsofWinnipeg.com>
> Bob Bruce wrote:
> > however when I try to use it on an area that will have a large
> imagemap,
> > I am finding that the imagemap is empty, an example of this is
> the South
> > Portage neighbourhood of Winnipeg, you can view it here:
> http://www.mappinggeek.ca/Mpages/indexMuralsMap.php?action=gotoneighbourhood&neighbourhoodid=80
> <http://www.mappinggeek.ca/Mpages/indexMuralsMap.php?action=gotoneighbourhood&neighbourhoodid=80>> in this case there is no imagemap produced to allow mousing actions for
> > the little red boxes.
> Which version of MapServer are you using? In 5.0 we fixed a
> problem with
> large legends that sounds very similar to yours:
>    http://trac.osgeo.org/mapserver/ticket/1946
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080225/7845fded/attachment.html
