[mapserver-dev] Is there a size limit on ImageMaps, and if so
can I increase it?
Daniel Morissette
dmorissette at mapgears.com
Mon Feb 25 13:24:07 EST 2008
Bob Bruce wrote:
> Daniel:
> I am using version 4.10.2 . Previously I had this working
> in a version of MapServer in 2005 and it is still working to this day at
> www.themuralsofwinnipeg.com/Mpages/indexMuralsMap.php with this old
> version (if you select the South-Portage neighbourhood it works fine).
> Now I wanted to upgrade to version 4 but wasn't ready to take the leap
> to version 5. Do you think that I need to upgrade to version 5 and
> rebuild MapServer etc.?
I don't know for sure, but chances are that the problem could have the
same root as the legend problem, that is: msIO_fprintf() returns
silently, without any error, if the output is too large. Based on a
quick look at mapimagemap.c that's probably not fixed in v5.0 for
imagemaps. It seems that the following patch (replacing msIO_fprintf()
with msIO_fwrite() as we did in ticket 1946 for legends) might solve the
problem for imagemaps:
--- mapimagemap.c (revision 7396)
+++ mapimagemap.c (working copy)
@@ -2029,7 +2029,7 @@
snprintf(workbuffer, sizeof(workbuffer), "%s",
img->img.imagemap+iIndice );
workbuffer[nSize-1] = '\0';
- msIO_fprintf(stream, workbuffer);
+ msIO_fwrite(workbuffer, nSize, 1, stream);
iIndice +=nSize-1;
if (iIndice < size)
If that works then please file a ticket in Trac and assign to me (Trac
id dmorissette) so that we include this fix in the next release.
Daniel
Daniel Morissette
http://www.mapgears.com/
