[mapserver-dev] Is there a size limit on ImageMaps, and if so
can I increase it?
Daniel Morissette
dmorissette at mapgears.com
Mon Feb 25 13:28:44 EST 2008
Correction... use this patch instead:
--- mapimagemap.c (revision 7396)
+++ mapimagemap.c (working copy)
@@ -2029,7 +2029,7 @@
snprintf(workbuffer, sizeof(workbuffer), "%s",
img->img.imagemap+iIndice );
workbuffer[nSize-1] = '\0';
- msIO_fprintf(stream, workbuffer);
+ msIO_fwrite(workbuffer, strlen(workbuffer), 1, stream);
iIndice +=nSize-1;
if (iIndice < size)
@@ -2039,7 +2039,7 @@
else
- msIO_fprintf(stream, img->img.imagemap);
+ msIO_fwrite(img->img.imagemap, size, 1, stream);
if( strcasecmp("OFF",msGetOutputFormatOption( format,
"SKIPENDTAG", "OFF" )) == 0){
if (dxf == 2)
msIO_fprintf(stream, "END");
Daniel Morissette wrote:
> Bob Bruce wrote:
>> Daniel:
>> I am using version 4.10.2 . Previously I had this
>> working in a version of MapServer in 2005 and it is still working to
>> this day at www.themuralsofwinnipeg.com/Mpages/indexMuralsMap.php with
>> this old version (if you select the South-Portage neighbourhood it
>> works fine). Now I wanted to upgrade to version 4 but wasn't ready to
>> take the leap to version 5. Do you think that I need to upgrade to
>> version 5 and rebuild MapServer etc.?
> I don't know for sure, but chances are that the problem could have the
> same root as the legend problem, that is: msIO_fprintf() returns
> silently, without any error, if the output is too large. Based on a
> quick look at mapimagemap.c that's probably not fixed in v5.0 for
> imagemaps. It seems that the following patch (replacing msIO_fprintf()
> with msIO_fwrite() as we did in ticket 1946 for legends) might solve the
> problem for imagemaps:
> + msIO_fwrite(workbuffer, nSize, 1, stream);
> iIndice +=nSize-1;
> if (iIndice < size)
> If that works then please file a ticket in Trac and assign to me (Trac
> id dmorissette) so that we include this fix in the next release.
> Daniel
Daniel Morissette
http://www.mapgears.com/
