Is MapServer Thread-safe?
Dan Little
danlittle at YAHOO.COM
Tue Jan 22 09:40:57 EST 2008
Adrian,
I don't mean this suggestion to upset the faithful, but it sounds like you might need a transactional solution better served with MapGuide OS or GeoServer.
2cents,
-Duck
----- Original Message ----
To: MAPSERVER-DEV at LISTS.UMN.EDU
Sent: Tuesday, January 22, 2008 8:36:38 AM
Subject: Re: [UMN_MAPSERVER-DEV] Is MapServer Thread-safe?
>Why do you think this is a "big limitation"? There are many MapServer
users, >myself included, running MapServer as a CGI application -
including
as a WMS >server - with "many clients running simultaneously".
What does mean "many" for you?
>What kind of equipment are you using and what kind of user load do you
expect? >It sounds like you have concluded that a standard CGI WMS
application of >MapServer is simply unsuitable for you, and I haven't
seen
information that >explains why you think that.
WMS is ok, but I need C# API to create any gis application (e.g. with
adding/modyfing spatial features, with requested by bussiness client
webservice interface, etc).
The problem is with scalability with using mapscript. Changing server
from 1
processor architecture to 4 performance will increase performance but I
think that not much in really big workload.
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080122/25cf2f32/attachment.html
