Is MapServer Thread-safe?
adrian kruk
adrian.kruk at GMAIL.COM
Wed Jan 23 03:07:06 EST 2008
> My first reaction is to wonder why you feel you need MapScript (which
> leads to the whole issue of thread safety in the first place). I would be
> inclined to build your application as I have done others, using the .NET/C#
> environment to process Web requests and then compute an appropriate WMS
> request to render the map image required. You would use MapServer in simple
> CGI/WMS mode, sending HTTP requests for images which you then retrieve in
> your C# code and embed in an output page of your design.
Ok I will give an example of functionality. MapScript has map object, shape
object, layer object, etc. With using these, it is simple to run query in
one layer, get results as shapes and then run query on different layer,
create new layer, then get image, i can store map object in application
cache in very simple way, etc, etc.
It is possible in CGI/WMS? If it is tell me how to do it.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080123/40be136d/attachment.html
