Is MapServer Thread-safe?
Paul Ramsey
pramsey at REFRACTIONS.NET
Wed Jan 23 15:31:00 EST 2008
Ed is totally on the mark here. There are very few applications that
REALLY, REALLY need mapscript. For most read-only applications, doing
your "logic" in PHP/ASP/Java, and then passing URLs back to mapserver
can give you everything you need. Note that you can over-ride *any*
mapfile parameter you want via the CGI interface (see "Changing map
file parameters..." at http://mapserver.gis.umn.edu/docs/reference/cgi/controls)
. Running your mapserv as a fast-CGI enhances your ability to scale
as well. For extra logic, serve your data layers out of a spatial
database, and use spatial SQL to answer the hard questions, and
Mapserver to render the answers.
P.
On Jan 22, 2008, at 7:13 PM, Ed McNierney wrote:
> My first reaction is to wonder why you feel you need MapScript
> (which leads to the whole issue of thread safety in the first
> place). I would be inclined to build your application as I have
> done others, using the .NET/C# environment to process Web requests
> and then compute an appropriate WMS request to render the map image
> required. You would use MapServer in simple CGI/WMS mode, sending
> HTTP requests for images which you then retrieve in your C# code and
> embed in an output page of your design.
