Is MapServer Thread-safe?
scott ellington
scott.ellington at GMAIL.COM
Thu Jan 24 14:27:50 EST 2008
I agree that most applications don't need mapscript, but I can confirm
that there are a lot of people who really, really want a .NET API for
doing GIS and mapping.
Scott
On Wed, 2008-01-23 at 12:31 -0800, Paul Ramsey wrote:
Ed is totally on the mark here. There are very few applications that
> REALLY, REALLY need mapscript. For most read-only applications, doing
> your "logic" in PHP/ASP/Java, and then passing URLs back to mapserver
> can give you everything you need. Note that you can over-ride *any*
> mapfile parameter you want via the CGI interface (see "Changing map
> file parameters..." at http://mapserver.gis.umn.edu/docs/reference/cgi/controls)
> . Running your mapserv as a fast-CGI enhances your ability to scale
> as well. For extra logic, serve your data layers out of a spatial
> database, and use spatial SQL to answer the hard questions, and
> Mapserver to render the answers.
> P.
> On Jan 22, 2008, at 7:13 PM, Ed McNierney wrote:
> > My first reaction is to wonder why you feel you need MapScript
> > (which leads to the whole issue of thread safety in the first
> > place). I would be inclined to build your application as I have
> > done others, using the .NET/C# environment to process Web requests
> > and then compute an appropriate WMS request to render the map image
> > required. You would use MapServer in simple CGI/WMS mode, sending
> > HTTP requests for images which you then retrieve in your C# code and
> > embed in an output page of your design.
