[mapserver-dev] Re: [MapServer] #2664: configure does not work for
fribidi2
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 3 00:45:34 EDT 2008
Daniel,
Trivial testing looks good. I tried it on a couple of systems and also
tried --with-fribidi-config=../fribidi/fribidi.pc which worked fine also.
I did get one error below but it seemed to configure and build ok.
./configure: line 11962: =: command not found
-Steve
./configure \
--enable-ignore-missing-data \
--enable-debug \
--with-httpd=/usr/sbin/apache \
--with-proj=/usr \
--with-agg=/u/software/agg-2.4 \
--with-fribidi-config=yes \
--with-gd \
--with-gdal \
--with-freetype \
--with-postgis \
--without-tiff \
--with-wmsclient \
--with-ogr \
--with-wfs \
checking if FriBidi support requested... yes
checking for fribidi-config... no
checking for fribidi pkg-config path... yes
yes, user supplied path to fribidi.pc
FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
make
./mapserv -v
MapServer version 5.2.0-beta4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
-Steve
Stephen Woodbridge wrote:
> Daniel,
> Awesome! I will jump on beta4 and let you know if I run into any problems.
> -Steve W
> MapServer wrote:
>> #2664: configure does not work for fribidi2
>> Reporter: woodbri | Owner: dmorissette
>> Type: defect | Status: assigned
>> Priority: normal | Milestone: 5.2 release
>> Component: Build Problems | Version: svn-trunk (development)
>> Severity: normal | Resolution:
>> Keywords: |
>> Changes (by dmorissette):
>> * status: new => assigned
>> * owner: aboudreault => dmorissette
>> Comment:
>> I have applied the patches in r7771, in time for 5.2.0-beta4.
>> Leaving ticket open to add relevant updates to README.CONFIGURE
