[mapserver-dev] Re: [MapServer] #2664: configure does not work
for fribidi2
Alan Boudreault
aboudreault at mapgears.com
Thu Jul 3 09:00:19 EDT 2008
The error (or my error :) ) is located in the configure.in line 1917.
I wrote:
$FRIBIDI_PKG_CONFIG = "no"
instead of
FRIBIDI_PKG_CONFIG="no"
Thanks for the bug report!
Alan
Stephen Woodbridge wrote:
> Daniel,
> Trivial testing looks good. I tried it on a couple of systems and also
> tried --with-fribidi-config=../fribidi/fribidi.pc which worked fine
> also.
> I did get one error below but it seemed to configure and build ok.
> ./configure: line 11962: =: command not found
> -Steve
> ./configure \
> --enable-ignore-missing-data \
> --enable-debug \
> --with-httpd=/usr/sbin/apache \
> --with-proj=/usr \
> --with-agg=/u/software/agg-2.4 \
> --with-fribidi-config=yes \
> --with-gd \
> --with-gdal \
> --with-freetype \
> --with-postgis \
> --without-tiff \
> --with-wmsclient \
> --with-ogr \
> --with-wfs \
> checking if FriBidi support requested... yes
> checking for fribidi-config... no
> checking for fribidi pkg-config path... yes
> yes, user supplied path to fribidi.pc
> FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
> make
> ./mapserv -v
> MapServer version 5.2.0-beta4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> -Steve
>> Daniel,
>> Awesome! I will jump on beta4 and let you know if I run into any
>> problems.
>> -Steve W
>> MapServer wrote:
>>> #2664: configure does not work for fribidi2
>>> Reporter: woodbri | Owner: dmorissette
>>> Type: defect | Status: assigned
>>> Priority: normal | Milestone: 5.2 release
>>> Component: Build Problems | Version: svn-trunk (development)
>>> Severity: normal | Resolution:
>>> Keywords: |
>>> Changes (by dmorissette):
>>> * status: new => assigned
>>> * owner: aboudreault => dmorissette
>>> Comment:
>>> I have applied the patches in r7771, in time for 5.2.0-beta4.
>>> Leaving ticket open to add relevant updates to README.CONFIGURE
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
Mapgears
http://www.mapgears.com
